Number on CA18DET computer, what do they stand for?
JDMSIL80
Im seeing ebay has a few Blitz ecu's for CA18DET but each one has a different number label on the computer:
My stock ecu reads #79, am I able to use of these tuned computer for my car? Thanks!
Dattebayo
Mine is a 98 too. I know it has something to do with wether the computer is compatible with your motor's sensors or the like for some other cars. Im not 100% sure if this is the same for CA's though. I know a few SR stories of guys having to swap ECU's cause they had a specific motor that would not run with a different number (probably a Kouki).
biosehnsucht
both mine are 78, which I know are JDM 5spd ecus.
not sure of other #'s myself.
redamnavit
JDMSIL80 wrote:Im seeing ebay has a few Blitz ecu's for CA18DET but each one has a different number label on the computer:
The numbers indicate different setups. Basically manual or automatic, and whether it uses an 02 sensor or not. The latter case is probably irrelevant unless the seller is from the UK.
More to the point, it may not be a good idea to use a pre-tuned ECU unless you know the exact setup of the car it was tuned for and you can replicate it and the octane of the fuel it was intended to run with. Otherwise (if you're set on the stock ecu) you'd be better off taking a stock ecu and getting it chipped for your car.
OKRB20DET
Car: 1990 S13 coupe
RS13 180SX ‘O CA18DET MT FR 23710-36F05 MEC-D016
