ninetyone300zxTT »
https://forums.nicoclub.com/ninetyone300zxtt-u266578.html
Tue Jul 26, 2016 11:02 am
I'm on the tail end of an engine replacement in my 91 TT, but I'm unable to get the car started. The engine will spin over, fuel pump runs, no error codes, has spark (although CAS had to be swapped from the original to the replacement), and I verified that the injector and spark connectors are on the proper cylinders. When I pulled the CAS out and turned it manually, I could hear the injectors, and I could see spark on the plug I pulled to make sure the PTU was functioning properly. The tach is also showing some movement when spinning the engine over.
I bought this with a locked up engine, so I've never heard it run, but I assume it did before the engine locked up. This was apparently a newer engine, so I had to swap the intake, CAS, and use the new injector plugs. I also had an ignition code with the replacement engine's PTU. Once I swapped back to the original engine's PTU, the code went away.
As far as I can tell, it should at least start and idle, or try to cough to life, but all I get is spinning and smell of fuel.
Where are some places I should start looking? Also there is a 4 pin square connector on the passenger side that I'm unsure where it plugs in.
