compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Thu Feb 10, 2011 2:28 pm
For f*** sake how about " welcome to Nico"! These are good questions that even people that have been on here couldn't figure out. As far as the brake. Booster there is a one way check valve ( already there but would check to make sure its working) on the fire wall to hold vacuum /prevent pressure. T off fpr. Vacuum line for bov and run a line from intercooler piping. To wastegate (unless you're running a boost controller which I wouldn't rec on stock motor) I would only run 7-8 lbs on stock motor/fuel system (which is what most internal wastegates open at ). As far as the maf you can put it before or after the Turbo called blow through. Most important get your ecu sent off to E-mance, jwt or enthalpy. For a fuel/Ignition map for your mods. Be aware the stock maf maxes out quite easily.
