noise inside the rogue
mmyye
Car: blue rogue sl awd, leather premium and moonroof
today i drove on the freeway with the radio on, i heard some noise from the shift, and also, from the upper winshield. i used my hand to push the ceiling up, u can hear the sticky sound, ( means it should be stick all together but they were apart) ... mine only 550 miles. already that many problems....
very disappointed with the quality.
exeunt
Car: 2008 Nissan Rogue SL AWD Phantom Pearl
Try reading the gear shifter squeak thread:
zerothread/294280
Rogue Man
Car: 06 Civic EX Coupe FG1
mmyye wrote:today i drove on the freeway with the radio on, i heard some noise from the shift, and also, from the upper winshield. i used my hand to push the ceiling up, u can hear the sticky sound, ( means it should be stick all together but they were apart) ... mine only 550 miles. already that many problems....
Your post makes no sense at all "sticky sounds means it should be stick together" wtf does that mean?! why are you letting small little minor things bug you? take it in to dealer to get it checked out.
Ticmxman
Car: 2008 Nissan Rogue SL 2WD Gotham Gray
Ditto
Return to “Rogue Forum”
