No spark, no fuel, what the hell!!
PapaBurgundy
Car: 1991 240SX coupe SE CA18DET. 99 Dodge 2500 Cummins TURBO DIESEL 5spd.
So I finally got my CA put together and it wont start, turns out I'm missing two important components to starting, spark and fuel. So I have power and ground to coils and injectors (DSM 450's) my CAS and MAF is sending all the proper signals, turns over great, I have two ignitor chips niether helped the spark all the connectors are plugged in properly and nothing helped. Is my ECU fried or what?
articzap
Car: 2014 F150 FX4
Is the ECU dead?
greensx
Car: 93 240sx hatchback
Any chance was this an auto to manual swap? Is your fuel pump turning on when you turn the key? These could be some problems for the motor not getting spark or fuel.
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
articzap wrote:Is the ECU dead?
before you make work harder, check the easy stuff....Fusebox...check it for the fuel pump...
i only thought of that because i wired my fuel pump fuse to be connected to a switch that i can cut on and off
which works as theft deterrent...my dad tried to take off with my car but then it died like 3 feet away from the driveway
PapaBurgundy
No transmission swaps and I know my fuel pump works because I tried starting the car but forgot to hook up the fuel lines first . Fuses are all good and how do I tell if the ECU is dead?
Rin5
fuel lines unhooked!? did your car go petro-bulimia? lol
ummm how do you check? uhh find the pin corresponding to your problem areas have the car in ON position and **pokemon** the pin with a multimeter?
**i meant to say poke**
atleast thats what would make sense to me
Modified by Rin5 at 10:51 AM 8/8/2008
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
what kind of ECU are you using? does it light up when you turn the car on? sounds like your body harness is good.....
PapaBurgundy
Stock ECU no tune.
PapaBurgundy
Anyone got an ecu for sale by the way?
PapaBurgundy
Red and green lights when I turn it on but I cant tell if I'm in diagnosis mode or not because the screw just keeps spinning, I assume thats not good.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
set the ecu to regular mode, and put a piece of putty on it to keep the screw in place till you can figure out what else is up. check EVERY and i mean EVERY fuse, fusable link, relay etc in your engine bay. also, if you have a multimeter check for power at the injectors and coil packs. check your resistor pack as well.
thinking of everything i can, good luck
articzap
Car: 2014 F150 FX4
Is your motor grounded? I know that sounds stupid.
PapaBurgundy
Yeah I got power and ground to injectors and coils and the motor is grounded.
