No Power to St Signal Fuse
Warlord22
Car: 89 240sx,90 Talon Tsi,01 Cougar
This Is how it all started while tighting the screw for the bleeder on the intake manifold the my socket touched the wire that goes to the fuel injector close to the front of the car anyway a spark came out so i stop and notice the wires were exposed so now my car wont start it tries to but just doesnt have that little umf so i checked fuses and notice the fuse for the st siganl under the driver side is not getting any power to power the fuse so what do i do now and i checked getting spark and fuel
vancouverbc
Car: 1991 240sx
Warlord22 wrote:This Is how it all started while tighting the screw for the bleeder on the intake manifold the my socket touched the wire that goes to the fuel injector close to the front of the car anyway a spark came out so i stop and notice the wires were exposed so now my car wont start it tries to but just doesnt have that little umf so i checked fuses and notice the fuse for the st siganl under the driver side is not getting any power to power the fuse so what do i do now and i checked getting spark and fuel
replace the fuse.
http://img169.imageshack.us/my...0.jpg
Warlord22
the fuse is not the problem i have replaced it wit 20 fuses the problem is where the fuses plugs into seems not to be getting power and i cant read wiring diagrams
nichols1992
What's you year, model, and engine size?
vancouverbc
Car: 1991 240sx
the start signal fuse only gets power when you turn the ignition key to start . the power is coming from the ignition switch.
Warlord22
89 240sx ka24e 4 cylinder 2.4 litter
Warlord22
when i turn the key to on is when i tested it and the fuse would not light after the tenth one so i took the fuse out and stuck the test light in where the fuses went and nothing so is what your saying i need a new igniton switch
nichols1992
Hey, the only thing I have to go by here is a wiring diagram of the fuse box, and I don't see anything labled St Signal Fuse. I know there are fuses and fusible links in the relay box as well as the fuse block. Maybe one of those is blown. I assume you've repaired the bare wires that you bumped, if not maybe you might have an open in a wire there. If the st signal fuse is fed by the ignition switch you can check for an open in that circuit using an ohm meter.
vancouverbc
Car: 1991 240sx
Warlord22 wrote:when i turn the key to on is when i tested it and the fuse would not light after the tenth one so i took the fuse out and stuck the test light in where the fuses went and nothing so is what your saying i need a new igniton switch
there is a difference between the start and on position. start is when you momentarily give power to the starter so the fuse should NOT have power when ignition is in on position.
Modified by vancouverbc at 7:56 PM 10/28/2008
Modified by vancouverbc at 12:29 AM 10/29/2008
vancouverbc
Car: 1991 240sx
before doing anythign else, check the brown fusible link 25amp . eng cont. check it carefully because most untrained people seem to miss that these fusible links are blown
Warlord22
so how exaclty should i check it then
Warlord22
the st signal fuse is in the fuse box inside the car on the driver side and on wht setting do i put the ohm meter bare with me i dont know **** about wiring
vancouverbc
Car: 1991 240sx
Warlord22 wrote:so how exaclty should i check it then
look in top window and see if fuse is burned. double check with ohm meter. set to 200 ohm range. or set so it buzzes when there is continuty. if it is open , you get a 1 which stands for open. also check the 10 amp fuses in the relay box.
Warlord22
sorry vancoverbc you were correct the fuse only lights up when i try to start the car so i guess thats not the problem correctso what now do i still have to replace the ignition switch or no and i am gonna try and do what you said also i really appreciate both you guys helping me out its good to know i have help
