leerandallstewart »
https://forums.nicoclub.com/leerandallstewart-u146108.html
Mon Jan 18, 2010 8:11 am
Things I would do (not necessarily in this order) but it's the order I would check. Eliminates potential causes as you go along.
First, look at timing.
Then re-check the fuel pressure. Just because it squirted does not mean that it is adequate.
Do a "double shot" of injector cleaner or Sea Foam - then replace the plugs (assuming that all of your coil packs are firing).
A good cleaning of the throttle bodies on the upper plenum could never hurt, but I doubt that would cause the car to not have any power. I would check the air filters though. If they are clogged, the car can't breathe.
