slugboat »
https://forums.nicoclub.com/slugboat-u215041.html
Sun Jan 27, 2013 7:38 pm
I think I have narrowed it down the either the fuse port, or a faulty fan. I took out the blower fan , it didn't have anything in it. I also checked all the visible connections. There is a fuse missing where I think it would control the fan, but that same port seems to be broken. Is there an easy way to bypass that? I am not 100% positive, but I am pretty sure I found the temperature control valve. It was under the dash on the passenger side, pretty close to the control station ( about as far left of the passenger side as it could be ). Also when I open up the vent and touch the heater core, it is warm, but I feel like it should be almost too hot to touch. The hoses running to it inside the cab get almost to hot to touch, so I don't think they are blocked off under the hood.
If I were to run water through the hose, were exactly would it come out, and would it harm anything? Is there anything I should remove before I do this? These are all my questions for now. Thanks again, I feel like I am pretty close to fixing it, but I couldn't have done it without you. Hope to hear back from you soon!
