Nissan Tiida/Versa 2010 Engine Vibrates only when hot and at a stop
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
zedebja
Car: Nissan Tiida 2010 Sedan
Morning Everyone. I am in desperate need of anyone help. I have a Nissan Versa/Tiida 2010 and i have been having this problem for over 2 weeks now and it is getting worst.
The problem is when i start the car on mornings it works perfectly until i drive it for a little while (maybe 15-35mins) and it starts to get hot, when i come to a stop while the car is still on D the engine vibrates the car where it shakes the whole car.
When on N it shakes but not as bad but any other gear R or P it shakes a lot. Here is what i have checked and done so far:
Replaced intake manifold rubber seal and checked the other seals as well
Checked coil pack and spark plugs and it was good.
changed coolant sensor
Change engine oil, filter and air filter
Clean throttle body
I dont know what else to do, i really need help. I just want to cry :-(
Someone please help me
I uploaded it video on Youtube of my car showing the problem called: NIssan Tiida 2010 Engine Vibration Problem
centralcoaster33
Car: 1997 Nissan 240SX #5
Hi and welcome to NicoClub. To me, it sounds like you have transmission issues, but you could be having idle issues. Your work up to now could have helped if it were idling issues. What RPMs does your car idle at when cold and when warm? Do you run your AC all the time? Do you have any check engine lights? Can you get an OBD-2 scanner and check your car for codes? A lot of car parts stores will loan you an OBD-2 scanner for free or scan it for you.
Just to be sure, you mean shaking vibrations that you feel, not sound vibrations that you hear, correct? Where does it seem like the vibrations comes from when you feel it? Steering wheel, your seat, the dash, the hood, etc.
You can use our website to download your FSM and look for diagnoses in there. At the top of the page it says Service Manuals. You can search for car shudders or car shakes during idle if that's the issue. You can probably call around to mechanics and find out which one does the most affordable diagnoses. They can test drive the car and hook it up to a consult machine to see if there is anything wrong that the car's computer is detecting.
zedebja
Hey everyone. Just want to update that the car is finally working. Thanks for all your assistance. The problem was the Oxygen Sensor 1. I change it and the car now works perfectly. Thanks again for everything.
Return to “Versa Technical Discussions”
