Nissan Driver »
https://forums.nicoclub.com/nissan-driver-u283265.html
Tue May 15, 2018 7:33 pm
Hi Guys,
I am new to the forum. I have an issue with my 2009 Nissan Altima. My car was recently in a wreck with gas front end damages with front driver Airbag deployed and both front passenger and driver seat belt locked. All cosmetic has been repaired. I replaced the impact sensor by the hood latch, both left and right from seat belts, spiral wire harness cable, Airbag sensor module ( located under arm rest. Looks like a hard drive), and Airbag. The current issues I have is that the Airbag Icon on the dashboard is flashing. I attempt to reset it by using the following steps Below that I saw online. My airbag light now flashes slower but still and flashing. I also disconnected and reconnect the airbag cables under both seats.
Recommended steps from online :
Follow these steps. turn your car on the on position DON"T start the car just turn to on as soon as the air bag light blinks shut it off count 10 seconds (slow). Repeat this 3 time after the 3rd time turn it back on it will blink on a different pattern this is how you know you did it right. Turn it off when you turn it back on the light should be gone.
Rogue One on Sat May 26, 2018 7:46 pm, edited 1 time in total.
Reason: Moved to correct forum
