newer style nissan mafs on S chassis?
katillidie
Car: 1990 infinity m30
93 s13 coupe vq35hr swapped
96 s14
2003 m45
2000 frontier
has anyone figured out how to make a newer style nissan mafs like whats in the 350z where the sensor can be unbolted from the housing.. work with older chassis's ex. s13/s14...so if i had a newer style mafs and an safc2 has anyone figured out the pin in/out setting for them? just curious. they are a dime a dozen around here i have 4 individual sensors and would like to try and put them to good use... thanx
Speckid4
Car: 1995 240sx
1993 240sx
Do you have cars that run and drive smoothly? If so then I would just leave them on the shelf in the garage. As far as I know its not possible, however, even if it is possible it doesn't seem like worth doing. Benefits?
katillidie
96 s14
2003 m45
2000 frontier
well considering i am useing a stock ka mafs... i want to upgrade, i have used z32 in the past but dont currently have one handy, i have the newer style laying around, it is currently in a 3inch tube so its the same as a z32 diameter, so why buy a z32 if someone has figured out how to use the newer style... just curious is all!
Speckid4
Car: 1995 240sx
1993 240sx
Are you running boost? Because otherwise there is really no reason to do so. :gotme
katillidie
96 s14
2003 m45
2000 frontier
Yes boosted
katillidie
96 s14
2003 m45
2000 frontier
so i guess this means nobody has dont this yet.... or it just cant be done...
biggie
Probably no use in doing it. Only reason people change MAFs is for more air flow and Z32/Cobra/Lightning are common and easy.
Could do about any MAFs if you can find a tune or use a SAFC for it I guess. Just the matter if you want to be the test subject that possibly blows their engine.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
This is something you will have to be a pioneer about. Rather get in touch with jwt or enthalpy and see if they have a tune for it (im sure they can make one) or start tinkering with it on an safc. If the resolution is anything like the z32 start with 2in and 6 out. It would actually be great to know if this maf is equal or better because that would make it as a used part not even 10 years old.
