Welcome to NICO!
Woohoo...another crazy Canuck
Of course you want to get a detailed History on the car
I think it's called Carfax.
Also for tips go here
http://www.samarins.com/check/index.html
Look here for common problems with that particular model, recalls, complaints etc.
http://www-odi.nhtsa.dot.gov/c...h.cfm
And lastly...Tire feathering occurs when the tread ribs actually scrape down the road. It's a common occurrence when the tire has a camber problem or needs toe-in or toe-out alignment. Reports of extremely loud tire noise (sometimes identified as tire roar or howling) almost always accompany the tire feathering problem. Once the tire wear begins, so does the noise. The more miles accumulated, the louder the noise gets.
Hope that helps...have a great day and Welcome aboard!
