I know that the stock s13 sr20det is on 7psi from the factory, and that the stock bottom end can handle around 20psi pretty easily and I have been reading that the stock t25 can handle up to around 13-15 psi before its outside its efficiency range.
But what I cannot find through my searching is what a safe modified amount of boost the stock (62) ECU's tune will be able to handle as well as what the stock injectors can handle without being into anything dangerous.
I'm just trying to squeeze a bit more power out of the stock setup until I am able to upgrade and I have been seeing alot of people saying that they are running 10-11psi on stock setups with no problem. I am not looking to get more than around 10-11psi but I want to make sure that I will not be blowing this thing up by doing so.
I am running a stock s13 redtop in my S14 with minimal bolt ons - intake, FMIC, exhaust manifold, 3 inch turbo back exhaust and wont be doing any modifications until I can get a wideband hooked up along with a boost gauge but I do not want to go into this blind.
Thoughts anyone?
