new to the forum got a issue
black01
Car: Black 01 nissan maxima gle straight pipe cat back
Hey guys im new here i have a 01 maxima gle the SES light has ben on and now its hard to start and missing wen its cold it runs fine wen it warms up and under power i need to fix it cuz its my wifes car the codes are P0135, P0430, P1335, P0140....can anyone help please and thank you......the car is compleatly stock excpt from the cats back i cut the resonator out and put a magniflow on it :confused:
black01
Well gyss nobody knows
Gotta give it a little time, dude. Welcome aboard...
P0135 - Bad O2 sensor
P0430 - Catalytic converter issue
P1335 - Crankshaft Position Sensor (common failure) http://www.courtesyparts.com/23731t-cra ... 30321.html
P0140 - Also bad O2 sensor
Start with the crank position sensor - Once you get it, we can show you the section of the FSM that shows how to replace it.
Are you sure you didn't mess with your O2 sensors? Regardless, it looks like they need replacing.
That should get rid of all your codes, unless something else is broken that we don't know about yet.
By the way - I think you might get a little better response if you proofread first (just in case someone's searching with the same issue as you're having). Hard to read "text-speak". Thanks! :)
black01
Nope never messd with the 02 sensors i jus cut the resonator out and put a magniflow on.....my issue was tha 1335 code i couldnt find out what it was ive had a bad 02 sensor forever but havent changed it but the big issue is why uts hard to start and missing but i think the crank sensor will fix it thank you
black01
Well calld napa and they said there is two kinds one on the side of the engine and ine in the fronr idk wich one i have any way to tell?
black01
Well replaced the crank sensor with a napa one $86 car runs like a top now and only one code p0135 il get a sensor tomarrow :cool:
ofromda860
Car: 2004 Infiniti g35 coupe
2015 Nissan Rogue
Hey did the crank sensor replacement fix the hard start issue? I have the same issue on 2k Max with 115k. I also have the P0135 code just pop up 3 days ago. You can private message me as well, thanks!
