well Kinda. people dont usually refer to Golfs and Jettas by Chassis code but rather by generation. Even though i got a MK5 GTI its chassis code is PQ35. Supras are also referred to as MK# (Mark generation number) . With Nissan its Platform and designation. So B13 is platform B designation 13 IIRC.shorerider wrote:ok so b13 is kinda like how on jettas they have the mkI and mkII and so on that makes sence..i dont no if a cold air and a exuast will give me the performance i want the suspesion i was thinking bout lowering it like 3 in and thank you for those ideas for the stiffer suspestion..thank you for the welcomeing so far im impressed with the forum thank you again
B16s are not at all related to B15s. B16s aren't even B-chassis cars, actually. They're on the shared-with-Renault's-Megane C-chassis. The Versa is actually more related to the B15 than the current Sentra is.aebstract wrote:That's your cars chassis type (I believe chassis type is what I'm looking for). It goes up: b13, b14, b15, b16. As the years go on and the chassis changes, so does the tag that goes with it. If I'm not mistaken, the b16 and b15 are very identical if not exactly the same in chassis, the only reason it carried on the b16 instead of b15 was because it was a new look. (I may be wrong)Short answer though, no that isn't your engine.
As far as upgrades, I would say to just stick with your basics: strut bars, sway bars, exhaust, cold air intake for starting out.
That's exactly why I said I think. Got it backwards.. see I remember reading something somewhere around here saying how its just called b16 cause its next but that doesn't follow suit like the rest of the sentras. Just had remembered it wrongly :Pnametakennow wrote:
which forum was that? (i think i know, heh)shorerider wrote:thanks alot for all your help the last forum i was on they wernt so nice i was kinda sceptical about joining this one but i see i have made the right choise thanks again and ill look into wat you guys have suggested
