r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Mon Sep 15, 2008 9:35 am
I run an adjustable FPR on mine. Might as well replace your stocker with the aftermarket one, as you probably don't know the condition of the stocker. They also look cooler than stock units. +1 for looking cool, the ladies love cool guys (not that I would know...wait).
Slap the Sr t25 on there. Stock boost pressure will be fine on the fuel system, and you'll pick up a couple of ponies.
I would replace all the gaskets (head gasket, intake manifold, exhaust manifold, thermostat, valve covers, etc), replace the water pump, maybe the oil pump, thermostat, and belts. You might also want to check the bearings and rings and see if they need replacing. For $300, you might well have to, but don't worry, they are pretty cheap. If you do all that you should be able to absolutely WAIL on it without any problems.
I think the wiring has been covered somewhere, so you will probably want to search. If you can't find it with NICO's search, try google, as it often finds threads on here that our search cannot. I have this feeling one or two small things might need to be changed with the SOHC to DOHC wiring with the CA, but I am unsure of what they would be.
