sherwooa »
https://forums.nicoclub.com/sherwooa-u271084.html
Tue Feb 18, 2020 8:54 am
If you compare the two, the overall diameters are roughly the same (within 0.4%) so you shouldn't see much difference in speedometer reading.
The tire is wider by about 0.7", so you will obviously see some effects from that - a bit more tramlining on highways, perhaps slightly higher steering effort, maybe a bit worse performance in snow (since narrower is better) but I wouldn't imagine it will be a major difference. Any particular reason you're looking to change the size and not go with the OEM sizing?
