hiimjered »
https://forums.nicoclub.com/hiimjered-u98712.html
Wed Jul 30, 2008 8:05 am
Just finished putting together a subwoofer box for my Versa. I decided to build it level with the hatch opening, so that I put together a platform on the other side and use the space underneath as storage.
Before the flaming begins, I know the wiring isn't pretty. It's current location is simply temporary. When I upgrade the door speakers I'll install a new amp for them under one seat, and a new subwoofer amp under the other seat. I just wanted something to boost the bass a bit for now.
BTW: The wiring for the subwoofer does exist back there, at least in my SL. That is where I got the signal and the turn-on from, so I didn't end up having to pull out my deck. I did run a new power and ground wire.
Regardless, the sound is much better.
Here you can see the box, and how it is fitted for the corner of the luggage area.
Here it is installed.
Here you can see how it is sized to fill the side of the luggage space. I have a metal grill to cover the speaker in case I need to use the space for hauling something. This will be even more useful for that when I move the amp.
