deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Wed Nov 12, 2003 6:21 pm
so what your sayin is your car will turn over (engine is spinning) only a couple times before it goes dead and then your relay goes click click when you try? I just didnt get what you said 100%
sounds like your battery, have another car jump you (when its running) and see if you get the same results. This problem has nothing to do with your coil/distributor it is associated with a weak battery/alternator. once you get it to turn over and its not starting (should be able to turn over for at least 45sec) then you should look into your possible spark, compression, and fuel issues.
