New SRcar problems.
Ghettopoptart
Okay,
Just recently purchased a 91 240sx, with an S13 Sr20 swap, the swap itself is VERY clean, the car runs great with the exception of having atmospheric blow-off and trying to die due to that and sometimes, it wont start, like not getting tach signal ,so i can get out, unplug the cam angle sensor, i hear what sounds like the injectors re priming (a whine). Then it'll fire up and run. But dunno if its the atmospheric or what that makes it laggy and studdery during the beginning of boost or not. Any takes on this? :gotme
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
When it doesn't start do you have fuel pressure? Sounds like a sticking eccs relay.
Ghettopoptart
I need to get a fuel pressure gauge for that , hmm. Ill check and get back to you.
hartig
the blow off valve shouldn't have anything to do with the car not starting.. unless its stuck open
which doesnt sound like the case
