NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Fri Jul 29, 2005 7:38 pm
well today sucked enormous a$$.
I managed to kill not one, but two water pumps WITHOUT even leaving the driveway. gaaaaarrrrrrrrrrrr!
today started off good, went for a test drive around town with the new s14 turbo. Turned it up to 10psi and damn does it move Feeling good about things, I then run into a huge traffic jam. Overheating soon occurs, leaving me stuck in a parking lot waiting for the car to cool down and limp it back home. Its been doing this to me randomly when I get stuck in traffic jams. Florida heat and humidity is taking its toll on my cooling system, and I started thinking of ideas of how to cool down my engine. I started by ordering a B&M oil cooler because hopefully if I cool down the oil some, the rest of the motor will remain cooler too. I also decided I should try putting my fan shroud and clutch fan back on, to replace my pulsar electric fan.
Everything is going well, get it all on there, and try to fire it up. Holy crap clutch fan and fan shroud pulls so much air the engine bay feels like a hurricane is happening in there. At this point I'm stunned, and very excited to see how this is going to affect my overheating issues. I try revving up the motor, and sudddenly all hell breaks loose. The fan starts wobbling all funky and starts tearing itself apart on the p/s pump and pretty much anything in that general area. I shut the car off, and determine the cause to be a twisted water pump neck. water pump #1 (CA18DE pulsar one) fails after appx. 30 seconds of run time with the clutch fan. This was the same pump that has lasted me for 2 years with electric fans!
At this point I'm feeling pretty upset, but I figure, no real harm done, water pumps are like $30, and thats not a big deal. I've done it before and I can do it again. I head off to advance autoparts. They don't have any 200sx RWD pumps, and the earlies they can get me one, Tuesday. Next I swing by Autozone, same story. I even called Napa, and they said earliest would be Monday. Damn. Oh well, I have a CA20E I pulled from my s12 in the garage with a basically new water pump on it that I got off ebay. It was marked "200sx water pump" but on the box it listed the CA20E stanza as well as the 200sx. It had the smaller water neck, but it was larger than the previous one I had. With no other option, I figured I would try out this one.
Pulled off the busted water pump, and reinstalled the new one. Everything went well (I'm getting to be an expert at installing timing belts) until I tried to start it. When I was setting the belt tension, I didn't realize the tensioner spring was stuck against the timing belt. When I tried to start the motor, this spring dug into the timing belt and made the engine refuse to start. The friction was too much. I pulled the timing belt covers off, and noticed the tensioner had pretty much shredded my belt up. Lucky me, I have another new timing belt in the garage from another project. So I get to reset all the timing one more time. This time I make sure there's no binding, and the engine starts up fine. I rev it up some in the driveway, and for the first few minutes it sounds nice.
after afew minutes I start to hear a clicking noise again, so I rev up the engine and lean in to see if I can tell where it's coming from. About this time the shaft (and attached fan) come flying out of the water pump, absolutely destroying my fan shroud and fan, killing the water pump (of course) and putting afew nice holes in my expensive god damn koyo radiator. At this point I decided, hell its time for bed, and walked inside
Tomorrow I'm going to Nissan to figure out when they can get a 200sx water pump for me, and I will be DAMN sure its the thick shaft one, and not this ***** FWD pump that grenades itself in a matter of minutes (with a clutch fan). So be warned, FWD pump and clutch fan really don't mix. What a day! I guess I have to find a radiator shop to patch up my koyo as well... money money money
Sean
