Well I finally got around to replacing the fuel pump and filter yesterday, I figured that I should replace both as they probably never have been replaced before (147k miles now). As I mentioned in the first post, This car has NO power. Under very light throttle the car seams to have plenty of power but as I lay into the throttle, the car just falls on its face. The car has more power when the engine is cold, and has more power when in manual transmission mode in gears 1 and 2 only. When using the torque app I found that the computer was pulling timing so much that it was reading zero degrees advance (typically around 30 degrees advanced). This all starts to make sense, the computer is pulling timing due to the lack of fuel. When cold, the engine usually requires more fuel or at least the computer wont pull as much timing, although I cant really explain why in manual transmission mode the first 2 gears don't pull as much timing as in 3/4/5 or drive.
Anyways, I purchased my new fuel filter and pump off of amazon, both parts stated that they fit a 2002 infiniti Q45, and started the job...
1.) The fuel filter that says works for a 2002 infiniti Q45, didn't work for my 2002 infiniti q45. The original fuel filter is large in diameter, and the replacement was smaller in diameter. I thought that Amazon had messed up so I headed over to Orielly Auto Parts to get the correct one, and they showed me the exact same incorrect one! I showed them the one that came out of the car and could not get a match on it. They stated that Infiniti used the same (i.e. smaller one) filter on all q45s from 96 to 05. They told me to go to the dealer. Screw that, I will make it work...
Here is a picture of the original filter left, and the replacement filter right.
Here is the original filter mounted
Here is the new "replacement" filter mounted
To get this to work, I was able to bend the bracket holding the filter so that it would match the diameter of the filter.
Then I had to reshape the filter strap for it to work with the new filter
I cut off the excess material, drilled a new mounting hole and deburred all the edges
Here it is all put back together
2.) The fuel pump that was supposed to be a direct replacement for a 2002 q45 is not a drop in replacement for a 2002 q45.
Here is a picture of the old pump on the right, and the new pump on the left. The look pretty much the same....except, the inlet on the bottom of these pumps are shown on the bottom left side.
The factory pump has the outlet on the top LEFT side, the replacement pump has the outlet on the top RIGHT side. Basically the factory pump has the inlet and outlet lined up with each other, and the replacement pump has the outlet on the opposite side of the inlet.
Mechanically I was able to mount everything up, but when I went to plug in the fuel pump wiring....The damn wires were about 6mm (1/4") too short!
Because the orientation of the pump outlet, the wiring connector of the new pump is now on the opposite side and further away than the original. Good thing the pump came with wiring that was a little longer, So I desoldered the original wires and soldered on the new ones.
I reinstalled everything and got the car running. This is like a totally new car! It actually has power! I know I still have to replace the knock sensors, but holy crap, this car moves and it does so much more effortlessly.
