plenum ring---well, you heard something fall.garageascent wrote: ↑Thu Jul 29, 2021 10:52 am
Alright guys - if you were a plenum gasket ring (the metal rings for the upper runner to intake manifold) where would you expect to be after a fumble a falling off the upper runners?
I had the plenum off and was in the process of pulling the runners off and heard the sound of the metal ring falling after I bumped one of the runners (runner closest to pass valve cover on front side of engine). Only found one of the two that dropped.
I removed the lower oil pan plastic cover in case it dropped and was resting there. No such luck. At this time I didn’t have any of the runners off and all of my intake valves are closed so it couldn’t have fallen into the engine. Any ideas?
Would you consider looking in and around the pulleys/timing cover? I’m pulling the radiator so there’s more room to look but I don’t like the idea of just ordering another one and cranking the engine over with the potential for that ring to be somewhere unfavorable.
Is it plausible that I am mistaking and it didn’t have a metal ring there to begin with? Since starting this year down I’ve noticed missing fuel rail bolts and the fuel rail spacers sitting in the valley, so I believe someone has been in here before.
Second question is on my FGY33 there is a gasket that goes between the two coolant flanges in the valley. I noticed the FSM only calls for Nissan liquid gasket. I have some but I was curious if you would recommend to move along as the FSM says or consider sourcing the metal gaskets? I believe they were only a few $ on IPD so it’s not a huge hit to the wallet if I get them and they don’t work.
usually, the metal rings stay inside the rubber rings. but I suppose with age and time and careless mechanics a lot of things are possible.
Maybe try a magnet drag?
I'll respond shortly on the y-pipe gasket
