New OS Giken twin disk clutch kit
CA19DET
http://cgi.ebay.com/ebaymotors...06841
i have read that this is the same kit for the CA18 (TS2BD) and will work with our starter..
Jezz_s13
Car: Sil80 Track Car
Cool, jez horsham is running a single plate one of these at ~500bhp so this should handle more than most are likely to throw at it.
That one looks like it's been at hte bottom of the sea for a while though.
I've just managed to get a triple plate one (TS3BD) after someone bought it in error for his SR, turned out to be the CA version.
CA19DET
^^ thats a very lucky find, i would love to get this one myself.. it looks like poo, but its brand new and i am sure works...
Jez
Looks like its in bad condition. Will it work with a CA without modifiaction??
Nowhere
Car: Suzuki x-90, samurai
Jez wrote:Looks like its in bad condition. Will it work with a CA without modifiaction??
Hehhe, the REAL question isWhat modifications have you done to your CA to require a clutch of that strenght!
NeedCAforS13
Car: CA swapped S13 coupe
haha, apparently you haven't seen jez's car!
Nowhere
Hmmm, 1,000kg/m is only about 700 lb/ft, Come on, my lawn mower has that, lol
You've got me salavating for his motor... lol
NeedCAforS13
thats not stock
Sean
themadscientist
Sorry but whether or not it's been used before, a part in such an atrocious condition could never be called "new"
float_6969
I think the more important question is, can you get replacement parts for it anymore?
Jezz_s13
yeah you can still get the rebuild kits.
I'm reasonably sure the triple plate stuff is the same bar the plate carrier (#2)
http://www.osgiken.co.jp/pro_c....html
themadscientist
the twin and triple baskets are interchangable on the flywheel. That's how I made a triple plate FJ, RB and CA clutch.
fallen180sx
Car: 90 Sil80
jez did you really run a 13.7 with that setup? if so im def backing out of the ca project.. thats a way pot load of money put into your car to run a second better then stock. i hope you were kidding.
Jez
fallen180sx wrote:jez did you really run a 13.7 with that setup? if so im def backing out of the ca project.. thats a way pot load of money put into your car to run a second better then stock. i hope you were kidding.
That was my real time. Its not setup for drag racing.
Jezz_s13
if you want a fast drag car, then get a better chassis and put the CA in it.
It's the chassis & balance that makes it a crap drag car, but is probably why it's a premio drift car.
silvia_ca18det
Car: 350whp ca18det drift silvia
i got that same clutch! and what a good clutch it is MMMMMM!
themadscientist
Jezz_s13 wrote:if you want a fast drag car, then get a better chassis and put the CA in it.
We have a local shop car, S13 Silvia with an RB26+T51R Kai @2.2 kilo that will click off 10s all day long. Building a drag car involves more than a powerful motor, you have to be able to apply the power.
