NEW MOTOR!!!
ca18deTbeGinNer
Car: JDM 190 Nissan 180sx - RHD byatches!!!
if anyone has a motor for sell, can you please let me know or email me at [email protected]. i would like to have one that has good compression and all 4 cylinders working. im running on only 3 right now and its only getting worse! thanks alot guys!
float_6969
why is it only running on 3?
boost_boy
float_6969 wrote:why is it only running on 3?
Yeah, that is a great question. Why???????????/
Dee
ca18deTbeGinNer
because when i pull out the coil for that cylinder when the motor is running, the rpms dont drop...but all the other 3 cylinders drop rmps alot when i pull the coil out. but im not sure if it is for sure a dead cylinder because the fuel injector for that cylinder is put together with electrical tape. so from the previous owner, i dont know what he did. im either gonna have to rebuild the motor, or replace the wiring that goes onto the injector for that cylinder...
boost_boy
ca18deTbeGinNer wrote:because when i pull out the coil for that cylinder when the motor is running, the rpms dont drop...but all the other 3 cylinders drop rmps alot when i pull the coil out. but im not sure if it is for sure a dead cylinder because the fuel injector for that cylinder is put together with electrical tape. so from the previous owner, i dont know what he did. im either gonna have to rebuild the motor, or replace the wiring that goes onto the injector for that cylinder...
It's not your physical engine, man. You have some electrical issues that need sorting. Make sure the engine is grounded properly including wires within the engine's harness.
Dee
ca18deTbeGinNer
would you happen to have any lying around?? or know someone that has the harness and some injectors??
boost_boy
ca18deTbeGinNer wrote:would you happen to have any lying around?? or know someone that has the harness and some injectors??
The injectors I do have, but as for injector connectors, I can give you what find because I really don't use my CA with the stock configuration anymore.
Dee
ca18deTbeGinNer
thanks for your help bro...the way the motor is running is making me worried so i wanna take care of it real soon. hahah, dude, i was going about 70 something on the freeway and i tried to pass a truck, and i was gonna hit 80mph, then my engine was kinda like bogging out or something. it was wierd and it freaked me out! i thought my engine was gonna blow! haha, but yea, if you know someone with a harness that would be great!
float_6969
I seriously doubt that the engine is bad. The easy way to tell would be to go purchase a compresssion tester and follow the info in the FAQ section and see what the compression is like.
ca18deTbeGinNer
i have done a compression test like 2 weeks ago. but i was told i did it "wrong" because i didnt have the throttle open?? when i did the test, w/out the throttle open the results were in the low 100's.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
ca18deTbeGinNer wrote:i have done a compression test like 2 weeks ago. but i was told i did it "wrong" because i didnt have the throttle open?? when i did the test, w/out the throttle open the results were in the low 100's.
You need to have the throttle open in order to get an accurate reading...go back and try it again.
float_6969
Yup, doing it with the throttle closed will yeild incorrect results. There is a post in the stickies that lays it out quite plainly. You can also read in the FSM, as it covers it there as well. Also remember that it has to be on a HOT motor. It should be as close to NOT as possible.
ca18deTbeGinNer
thanks guys, by the way...what should the compression be?? i heard no less than 150?? i will try it out and let you guys know what happened.
float_6969
Do you not have a copy of the FSM (Factory Service Manual) downloaded? If not, it's in the FAQ. Download it. NOW. You'll thank me for it later. It's got all kinds of great info in it. Much like the answer to the question you just asked...
