Silva1181 »
https://forums.nicoclub.com/silva1181-u303479.html
Tue Sep 28, 2021 6:03 am
Hello All,
As I have been looking for a used QX70 for a few weeks, I've been reading through many threads for the past few weeks as a guest and there's definitely lots of good information on this site. I finally decided to purchase a 2015 QX70 with 67k miles, 1 owner. The QX drives great, a bit bumpier than what I am used to but not bad. I plan to go to the infinity dealer where the car has been serviced since 2015 to obtain a copy of the maintenance records. It appears that the previous owner maintained and kept to the maintenance schedule. I do plan to have the transmission fluid changed, even though I read mixture of different responses about doing this.
The only mod I have done is to change my interior lighting to LED's, which is simple enough to do. Other than this I do not anticipate any other changes.
I do have a cracked driver side fog light and plan to buy a used one from Ebay, however I am only finding passenger side housings. Is there a difference between left/right? Also, after reading so many threads on this site and others, it's still unclear to me how to remove the housing as most info is about changing the bulbs. Is the housing held in by clips or screws? I appreciate if someone could direct me to a DIY write up or video.
Thank you,
Marc
Rogue One on Tue Sep 28, 2021 8:45 am, edited 1 time in total.
Reason: Revise title
