Ah, that explains it completely. Thanks VStar.VStar650CL wrote: ↑Mon Dec 06, 2021 8:41 amThere was a hack around Thanksgiving and pretty much all the posts between Nov 19 and Dec 1 were unrecoverable. See this post:
november-service-interruption-please-read-t630160.html
VStar650CL wrote: ↑Mon Dec 06, 2021 9:10 amIf I recall your original post correctly, there are a couple things you could check. The headlamps have separate left/right relays with separate fuses, so it's fairly unlikely that anything there would cause both headlamps to malfunction. They also use different grounds, and the only common circuit elements are the fusebox main supply, the headlight control unit and the wire going from it to the relays, and the combination switch. You already replaced the latter and the ballasts, so check the Purple/White wire at either one of the headlight relays while the headlights are misbehaving. You should see 0V or very close to zero. If not, there's either a problem in the PPL/WHT wire or a malfunction in the Headlight Controller (underneath the left kick panel). If you do see 0V then check the fat RED/YEL wire from the relay, if that's hot then your problem is in the headlights or the ground wiring. You can run a voltage-drop test on the grounds to verify those. One last thing, you didn't mention if you replaced the Ignitors (the steel-clad wires connecting the ballasts to the bulbs). Those aren't simply wires and they can fail.
That's ok, there's plenty of stuff I'd rather just forget about anyway. The purpose of the controller makes sense now. I hadn't considered what managed the auto functions. I'll test as you suggested and report back.VStar650CL wrote: ↑Mon Dec 06, 2021 2:52 pmThe Controller reads the switches and then turns the relays on as commanded. It's mostly there to give you auto lights and auto shutoff when the lights are left on (a dinosaurian leftover from the pre-BCM era). The tests I outlined should give you a good idea of whether the problem is in the Controller or the lights themselves.
As for my "fantastic" memory, that's actually the first thing that goes with old age. And the second thing is... umm... umm... patience, it will come to me...
I think we are making progress here! So I need to probe both of the red/yellow wires (I sure hate piercing the insulation, but don't see another way) and verify power while the lights are acting up; I suspect they will be hot as intended.VStar650CL wrote: ↑Wed Dec 08, 2021 5:16 amThe 36mV on PPL/WHT is essentially ground, so your controller is working. The fat RED/YEL on each relay is the output to the headlight, if those are hot then the relays are working and your issue is in the headlights or headlight grounds. Frankly this sounds like your high-voltage supplies are cutting out, so back to the original question, did you change the Ignitors along with the Ballasts? If not, that's probably your issue. If so, check your power and ground at the Ballast connectors.
To be clear, are you referring to new, current production Matsushita ballasts/igniters? Do you have a link to an example? I think I have to take the front end apart and remove the headlights again to get the part numbers off the ballasts, and the passenger OEM replacement was labeled in Japanese, so I'm hoping it shows an English number. I know the passenger side is the smaller style ballast with the single plug on it, but not sure if the other side is the same yet.VStar650CL wrote: ↑Wed Dec 08, 2021 8:49 amHID systems are basically high-voltage arc welders inside a bulb, and the ignitors basically contain a capacitive jumpstarter for the arc. I never replace ballasts alone, I always get them with ignitors because the ignitor is the problem at least half of the time. Bad news is, ignitors are hard to find separately. Good news is, you don't need to use Nissan ballasts or ignitors. Matsushita and it's China subcontractors make probably 99% of the world's ballasts, so the cheaper ones on eBay and Amazon are generally fine as long as they have a Matsushita part number. Grab that off your ballasts and then use it to find compatible ballast-with-ignitor combos on the net. The Matsushita number for Nissan ignitors will usually start with EANC for the small-housing types or LENA for the large housings. Pretty much anything with the right series numbers and connector cavities will work.
It's identical to the original OEM ballast I removed, except for the Japanese writing on the label. It appears there were two versions used in the early 2000s, a rectangular ballast with two plugs and the one in that picture, which is the one mine uses. So now I'm back to confused again.VStar650CL wrote: ↑Wed Dec 08, 2021 10:41 amYep, that's definitely an oldie. I'm not even sure that's OE, the WD's just show power wires in and low-beam wires out, with separate high-beam connections. That looks like a combo setup for a bulb with a high/low aiming solenoid.
VStar, I wanted to take a minute to thank you again for all of your help. I FINALLY got around to working on the lights again this weekend (busy college kid schedule, snow, etc.) and they appear to be good to go.VStar650CL wrote: ↑Wed Dec 08, 2021 4:31 pmThere are actually two SM's depending on your VIN. They have the earlier version here in Nico, for VIN's up to 200000 for 2WD and 200100 for 4WD. Here's a link, the headlight WD's start on EL-29:
https://www.nicoclub.com/service-manual ... 0%2FEL.pdf
For VIN's 200001+ or 200101+, here are the WD's only, I can't grab the whole section:
