New knock sensor, O2 sensors but never gone Check Engine Light.
Ryan Heo
Car: 1996 Infiniti I30
Hi.I got Check Engine Light a month ago, so I went to scan the code at Autozone. They show me the O2 sensors and knock sensor are malfunction.After that, I replaced all of the sensors but the CEL is still light on.I scaned again, they showed the same code which was already replaced by new sensors. What should I do next? or How to check the new sensors are working properly? Would you let me know how to get rid of the light?Thanks.
Modified by Ryan Heo at 12:38 PM 7/2/2007
Black stallion
Car: 1994 Infiniti Q45
2006 Infiniti QX56
Try getting the ecu to "reset" itself
Ryan Heo
Sure, I did 3 times already.I think I need to check wire, but I don't how to check it.That's my problem.Thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Wiring sub-harnesses are usually replaced also, expecially the KS ones.
