I'm using Champion Double Platinum tipped plugs. I'm going to guess that that's a bad idea and I should go switch to NGK Iridiums or Platinums. Should I get the double tipped NGK's or the Irridium V's?misfit6794 wrote:The ball joints are cheap, the labor is not.
As far as the engine, I put ngk iridiums in mine without problem, but some people have problems when they don't use platnum tipped plugs, there is even a factory sticker under the hood telling you to not use anything else. THere can be a ton of things that are causing your motor problems. I had a similiar issue, and it turned out to be 2 bad injectors. Replacing those are a pain. The best thing you could do is pull the codes to see whats going on.
The only suggestion I have for you at this point is for the engine knock. I found somewhere in this forum where someone mentioned Auto-rx for issuse with the rear main seal which I am having with my car. As I was reading all the things it was good for I decided to give it a try. Basicly, its an engine cleaner, and your problem could simply be sluge or other gunk. I also had a mild cold engine knock in my car when I bought it (only a month ago). I put in Auto-rx two weeks ago and already me engin is running smoother. The cold start knock is all but gone. It used to last 20-40 seconds, but now last only three seconds tops. My milage went from 24 to 26. So far I like it. Might be worth looking into. Kinda expensive, but for me it was worth the chance to save nearly $400 to replace the rear seal, and get a clean engine at the same time.[URL]http://www.auto-rx.com[/quote[/URL]]
I will certainly think about that. I used Motor Flush before I changed the oil, and I always use Lucas in place of a quart of oil to maintain seals in the engine.
What I'm looking into for better fuel economy is a fuel heater. It's a little copper tube that runs fuel around the coolant line (it takes place of a piece of the hose) which heats the fuel up for better atomization. That would be neat. But first, the plugs, and the filter. Maybe I have just 'simply the wrong plugs', because the knock wasn't there before I switched. That could be my entire problem.....
Yes, sounds like a great deal. (I should know, I sell em for a living.)Leuthesius wrote:I am now the proud owner of a 1996 Infiniti J30. I bought it with 116,000 miles for $2950. From what I've seen, that was a steal. :3
I've never replaced the ball joints on either of my Js so I don't know what to tell you about that.Leuthesius wrote:Now I have a few problems with this vehicle, which is probably why I was able to purchase it for the price I gave for it, and the possibility that the previous owner didn't know what he had.
Problem #1:
Lower ball joints: I have taken a look at my suspension, and I have spoken to an infiniti dealer. They have told me that I have to replace the entire control arm to take care of a ball joint that I should be able to buy for all of $20. Now... $200 for a control arm, or $20 for a ball joint. Let me think?
The ball joints clearly have a seed clamp, which means that it is being held in, which means that they can be pressed out/pressed in. But I cannot find an aftermarket seller of these ball joints anywhere. They all say you have to replace the entire friggin' thing. Is there somewhere where I can get the exact specs of the ball joint so that I can match it to another model/make vehicle and therefore save myself $800 for the whole car? I really do not want to replace every control arm when I can just replace ball joints.
Don't know which you are talking about.Leuthesius wrote:Problem #25 Link suspension? What in tarnation is that friggin thing that connects between the strut and the control arm that looks like to ball joint ends? No clue what that even is. The 1995 Altima I have doesn't have anything like that. No clue what that thing is....
Your car was rated 18 city and 23 hwy brand new. I really think there is something fishy about your 29.1 mpg number.Leuthesius wrote:Problem #3Knocking. I'm getting a strange knocking in the engine that has gradually progressed towards "not good" as I've driven it over the last couple of weeks or so. I can tell that it's coming from the middle cylinder on the left side of the car, but I cannot tell if the knocking is fuel related (I fill it with premium), fuel injector related, or if its the lifters knocking or the valves tapping. It does not sound like I've thrown a rod, thank god, but it still unnerves me. Also, as this sound has progressively gotten worse, my fuel economy has steadily dropped. I was getting 29.1mpg (which is wayyyyyyy more than this car is supposed to get) when I Was bringing it home, but am now lucky to get 18-19. I checked the compression in every cylinder and I'm getting 10.5 or better on all of them.
I love the Lucas products but one question, if you are spending all this time and money (Lucas stuff aint cheap) then why not go ahead and use synthetic oils?Leuthesius wrote:I just finished a full tune up of the vehicle. and I used motorflush to clean the engine out before the change.3qts castrol gtx + 1qt Lucas + wix filter for the engine (is this a 4.5 qt engine?)7.5qts DexIII Transmission fluid + 24oz Lucas stabilizerLucas Rack&Pinion fluid for the power steering (it was dry when I bought it)
Those are not OELeuthesius wrote:Champion (OE) spark plugs
This is a good thing.Leuthesius wrote:Trans-Cool Transmission cooler (since these things are notorius for the transmission overheating and seizing from what I've heard/read) located behind the A/C Condenser.
Including the timing belt?Leuthesius wrote:Replaced all of the belts.
Get the OEM NGK plugs.Leuthesius wrote:Do I need different spark plugs? Do I need to do something else? This is a completely different beast from my 95' Altima GXE, that's for sure. But its sould is still a nissan so I'm hoping I can work with it.
Leuthesius wrote:Oh, and it's a good thing that you guys have an FAQ for the fuel filter issue. I about had an aneurism trying to get that damned thing off....where exactly is that fuse?
So I actually convinced someone on here to try it?rclem7 wrote:The only suggestion I have for you at this point is for the engine knock. I found somewhere in this forum where someone mentioned Auto-rx for issuse with the rear main seal which I am having with my car. As I was reading all the things it was good for I decided to give it a try. Basicly, its an engine cleaner, and your problem could simply be sluge or other gunk. I also had a mild cold engine knock in my car when I bought it (only a month ago). I put in Auto-rx two weeks ago and already me engin is running smoother. The cold start knock is all but gone. It used to last 20-40 seconds, but now last only three seconds tops. My milage went from 24 to 26. So far I like it. Might be worth looking into. Kinda expensive, but for me it was worth the chance to save nearly $400 to replace the rear seal, and get a clean engine at the same time. http://www.auto-rx.com
You could put 10 of those on your car along with 2 turbonators and a tornado and a e-ram charger and it won't do a durn thing for your mileage.Leuthesius wrote:What I'm looking into for better fuel economy is a fuel heater. It's a little copper tube that runs fuel around the coolant line (it takes place of a piece of the hose) which heats the fuel up for better atomization. That would be neat.
-- Zomfg, is the gr81 fallible? Don't get me wrong I love Honda, actually been in the Honda camp longer, but... did you just advise someone to buy a Honda? Really I'm just messin' with you, usually your answers are less broad, moe specific, structured and scientific. You and Yoda have great info. My Honda (Acura Legend) gets almost the exact same mileage as my J30, but I guess it is two-tenths of a liter larger, so mileage is tecnically better. Either way Honda and Nissan pwn all others, eff gas mileage.gr8scott72 wrote:The easiest way to drastically up your mileage is sell your J and get a Honda.
Yes you did! I figured $77 for four bottles vs. $400 to change the rear main was worth a shot. And if nothing else, I will have a clean engine right? And beleive it or not, I used Sea Foam to flush the engine first. I also used it in the gas tank when I first bought the car. It's hard to say, but seems to work pretty good. I'll keep you updated on wheater Auto-rx works on the seal or not, will probably be 3 more months before I know for sure.gr8scott72 wrote:
The before and after pictures on the Auto RX site of the 240sx showing under the valve cover astonished me.
Thanks! Glad to be here. This is already an incredible resource and I'm going to problem even frequent the Altima part of this board (provided it's there)gr8scott72 wrote:Wow, were do I begin?
First off, welcome to the board!
Where do I find the ball joints? I've spoken to a dealer and they want to sell me the whole control arm. I need specs, or other vehicles that the ball joints match so that I can lie to a parts guy.misfit6794 wrote:The ball joints are cheap, the labor is not.
They are tension arms. Look at the fuzzycats.com site under tie rod replacement.Leuthesius wrote:I had the front end and all of the suspension checked today. I need to replace those two things that connect towards the front from the control arms.
What are they? Don't even know what they are!
I told you in an earlier post on this thread that you could replace just the bushings. I got mine AT the local Infiniti dealership and found a shop to press them in for me.Leuthesius wrote:Where do I buy them? I'm not finding anything I'm comfortable with. I need two stabilizer rods and tension arms according to fuzzycats. But the only one I can find is frigging $129 on Everything Infiniti and I'm not even getting a description. It just says "2 way steering" when I try to find the arm.
Can I just replace the bushing inside? I've found a "radius rod bushing" at the parts pin that looks like it could be pressed in.
Augh! Frustrating! >.<
