Alright, here's what those bushings should look like, and what mine looked like when I was done with them.. This was the source of most of my alignment issues, and the reason I was wearing new tires down to wires in weeks.
I used anything I could find to get these pressed in, anchor bolts, washers, even an old wrench, anything that would put the compression force on the outer layer of metal instead of prematurely blowing the bushings by compressing the inner sleeve first.
All back together (yea I know I'm missing a nut on the upper control arm, I left it at the other shop 20 miles from here lol >.< visio pocketed it for me though, what a guy!)
And finally! still have 215's on the rear lol, so no full shots yet.
Took it for a spin part way down the road and back, if a half dozen water bars doesn't settle out a suspension, nothing will. Can definitely see I'll need some more adjustment to the torsions.
Better yet, the manufacturer recommends setting the gap between the limiting pad to 1/2" and no less. Looks like I will be gaining yet another inch. I'm stoked! and I'll take every bit of lift it'll give.
I heard a slight clunk in the steering on my test drive almost at the end of a hard left turn. I'll go through it again tomorrow to make sure everything is tight and get those torsions dialed in. Next on the list is pulling apart the hubs, replacing rotors, studs, bearings, seals. replace the boots on the cv's, and replace a broken snap ring on the driver side cv. Then I'll address either rebuilding a weber or buying one new. I'm having some seriously whacky issues with this carb. Also sooner than later I'll have to tear my exhaust out again, this time all the way up to and including the collector and welding the piss out of every leak I can find. I'm contemplating on double mufflering this truck unless I can find a really quiet muffler. It's not a v8, nor can it tack out at 9k rpm, nor can it beat even a stock volkswagen bug in a race so I don't see any reason for it to be noisy, and it gets old fast when you have over an hour commute morning and night.
Hope to have some pics soon on 31's all the way around.
