audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Sat Mar 31, 2007 5:45 pm
Congrats on the purchase and welcome to NICO. I'm looking at '07 Sport Sedans myself.
From an audiophile perspective, the Bose blows. Sure, they are doing a lot to upgrade factory systems, but there are always improvements to be made. For the most part, you will need to find out if there is a RCA-level converter around for the '07 headunit wiring harness. If so, then you can simply run the outputs to new amps and new speakers (yes, you would need to replace everything but the headunit). If you go that route, I would suggest spending the money for a JL Audio CleanSweep.
Not sure about the rims on the '07 as I do not know what size and offset they are. I doubt you will need to replace studs for a simple rim swap. Now, if you need spacers > 10mm then that is a probability.
