New Deck Problems (need help)
Drewsfrontier
Hi Everyone,
I installed a new deck in my 2001 nissan frontier. The deck is a panasonic touch screen. After i bought the wire harness and installed it, my instrument panel lights stopped working. Also my dimmer switch stopped working. Can someone help me or provide a radio wiring diagram?
Thanks,
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
You cut the Illumination wire didn't you? Without it the dash lights are dead.
Drewsfrontier
i'm not sure what colour is it and what do i connect it too?
kmyers
Car: 1996 nissan pickup
If you use a harness it will make a continues loop to the dash. If you didnt use a harness then probably just connected it to the cd player. And that would be where your problem is. And the wire WILL be yellow. Almost all cars lighting is yellow.
