Perrenial Badass wrote:Pictures?
Pictures soon, once I get it on the road. It's on jack stands now since I posted earlier.
So far I've rebuilt all the brake calipers with repair kits from Partsbin, replaced one e-brake cable (Z31partsfroryou.com), headlight switch (also Z31partsfroryou.com)and taken apart the front of the engine to do the timing belt, replaced the camshaft and crank seals, water pump and thermostat.
Finally have all the parts do the timing belt e.g.: belt/tensioner/bolt, waterpump, thermostat and a couple of hoses from NAPA, CHTS and FPR from Steve at Z31partsfroryou.com, sub harness from AZ-Zbum's link (in WA).
Also a friend let me strip his '86 of some things, of note are a pristine rear hatch padding under the carpet, set of (also pristine) weatherstripping (T-tops/door) to replace the failing ones on the car, drivers seat and everything I wanted off the engine (AFM, P/S pump, FPR, O/S A/C compressor, lots of electrical connectors, O2 sensor, fuel pump etc. and etc...
I also have some rust through to attend to, not much but the rear wheel wells are rusted through at the front where the frame rails end, I don't have a welder but thought I might try the 3M panel adhesive and rivets, or should I take it to a body man to have it welded in?
Also what do you guys do with coolant hoses? Use the OE wire clamps or replace with hose clamps?
How about valve cover gaskets? Use OE or Permatex (or like) black RTV?
thanks
Bob
