adubon wrote:If you can't find the leak, you may just want to get the 1 piece ss line that goes from the master to slave cylinder. That way there are only 2 places that it can be leaking, either at the master or slave connections, nothing in between. Also, you will only have to bleed it at the slave.
Agreed, eliminate that 3rd bleed point. If you search around, you don't need to replace the entire line from the master, but get an adapter to eliminate the 3rd bleed point which is one stupid design.
Also, make sure you are bleeding it correctly. Start with the slave and bleed it. Then move to the alternate point and bleed it. *it is located on the passenger fender well. Repeat several times. Odds are, you still have a ton of air in there.
