Postby
daniel240 »
https://forums.nicoclub.com/daniel240-u4418.htmlSun Mar 02, 2003 7:40 pm
well it sounds like whoever did your exhaust did a bad job. they should have used the stock hangers and they should be rubber mounted so it doesnt shake your whole car. correct me if im wrong but if you order an exhaust system for your car it is supposed to fit and hang on the stock hangers. it sounds like yours are either missing or not hooked up right. and if your cat is welded on then you will need to buy a new cat or test pipe if you want everything to bolt up.
Postby
skwertle »
https://forums.nicoclub.com/skwertle-u186.htmlSun Mar 02, 2003 7:40 pm
Tino wrote:no no it's setup fine but it's too loud for my taste.
err.. yeah sure dude. =)
in my situation the muffler just isn't hooked up rite. the whole thing is off the the left and the pipe vibrates and hits a part of my car underneath shaking the whole car.
so i need a cat or a test pipe to connect the headers to the exhaust correct? So can i just buy one of thoughts 3 inch test pipe i've been seeing?
Postby
skwertle »
daniel240 wrote:yea just make sure its for the 240 and it should bolt right up as long al you get a cat back
it will be for sure and btw sweet car.
thanks for all the advice er'body. MikeMurphy, i will get a high flow cat-converter. But as soon as stops to be my daily driver it's comin' out, i tell u what. =)
