Your assumption would be completely wrong.aebstract wrote:Use less throttle when I'm trying to push myself through turns and get back up to speed as quickly as possible? No thank you. I'm going to go under the assumption that you have never experienced this problem or if you have, it wasn't bad enough for you to really realize what is going on. It's not a 1 inch jerk, it can be bad enough to almost pull me in to the other lane at times. I'm not gonna say that I can't keep my car under control and that I can't completely prevent this from not staying high rpms, but that defeats the whole purpose. I know there has to be things that aid in fixing this issue. I'm sure wider tires would be a little bit of help, some sort of custom suspensions supports maybe.
That's my point, YOU'RE pushing the car too hard. It's not built for what you want it to do. If you're serious you will upgrade everything. Start small start big, whatever. As you stated you noticed an improvement with your strut bar. Continue.aebstract wrote: you came in here giving me information that has more to do with me than the car.
http://www.yoostar.com/perform...=6324VMPhil wrote:i was under the impression that LSD exacerbates (Sounds dirty) the problem of torque steer?
i love that movie
