need input from experianced CA people.
btustison
I hate to bring it up because it seems to be a fairly common question, I searched and decide I was maxing out my MAF because I have been hitting the nasty cut at 4000rpm (or so). So then I remembered that there was a 50% chance i had a NA MAF. So I went to my shop and pulled the MAF and M's cone adaptor with a big velocity stack off of another CA18DET clip... so the car pulled to redline smooth on 13psi (s14 turbo). I had the car on the dyno today and it was cutting on me again, but on the street I can drive around the cut as long as I ease the car up to 4 grand...So my question is if this the result of a overworked AFM why does it cut in a small section of the powerband? It seems logical that it would cut out at full boost at any point above the initial cut.I don't expect anyone to give me a perfect explaination I am just looking for more input than "you need a Z32 MAF"
biosehnsucht
the stock ECU map also has a cutoff based on RPM bands for max airflow reading, if you go over this it cuts fuel. If you make too much power too low it'll cut on you.
Dattebayo
Yeah, a new ROM with the fuel cut removed and better maps would benefit the most, getting you away from that problem. This is the advice I learned from here...
btustison
Thanks a lot guys, that cleared things up.
