waynosworld »
https://forums.nicoclub.com/waynosworld-u255528.html
Sat Aug 29, 2015 11:39 am
Maybe I should have worded it this way, I believe that the 320, 520, and the 521 use the same steering column assembly, so if the 320 steering column assembly cannot be repaired, then you could look into finding another column assembly from later models, as there are a lot more 520s/521s out there than there are 320s.
The 320/520/521 share a lot of steering parts, you can use the smaller 521 idler arm on the 320, that is a good one to use if your putting an A14/15 in your 320, as the 320 idler arm gets in the way of the "A" series oil filter.
