I've been studying the FSM's (and my observations of my ecu wires) and gotten the info below: Just trying to make sure I get all the wires hooked up right....
I am fairly certain these connections will be correct...they seem easy enough:
RB20 engine -----------------------------------------------------------1993 auto D21 KA 4cyl
pin 7 TACH (yellow/red) -----------------------------------------------pin 2 TACH (white)pin 53 SPEEDOMETER (yellow/green) -------------------------------pin 32 SPEEDOMETER (white/blue)pin 18 FUEL PUMP RELAY (black/pink) -------------------------------pin 104 FUEL PUMP RELAY (white/red)pin 44 NEUTRAL SWITCH (green/red) -------------------------------pin 35 (NEUTRAL & INHIBITOR SWITCH (blue/black)
Those are easy enough to figure out....not even required for the engine to crank, except grounding the neutral sensor, I think...hehe.
These are mostly IGN and ECU power wires, I think...But I need to know what wires to connect. If you can use the PIN # on the ecu harness and the name of the signal it would definitely help alot...I want to be careful with this stage...
RB20 ENGINE
pin 43 IGN Switch Start Signal (from key, right??) (black/yellow)pin 45 IGN Switch {IGN} (black/red)pin 49 Control Unit Power Supply (black/white)pin 58 Battery Power Supply (white/black)
Hardbody KA ECU old wiring
pin 1 IGN Signal (to the ign coil, right??) ------------------ (white)pin 3 IGN Check (huh???) ------------------------------------ (white/green)pin 4 ECCS Relay {Main Relay} ----------------------------- (blue/red)pin 34 Start Signal --------------------------------------------- (Black/yellow)pin 36 IGN Switch --------------------------------------------- (black/white)pin 38 Power Supply for ECM ------------------------------- (black/white)pin 47 Power Supply for ECM ------------------------------- (black/white)pin 46 Backup Power Supply (direct to 12v, right??) --- (white)
I know I need to hook up the RB wires: white/black, white/purple, black/red, and on the alternator: white/red. Where do they go??? I had these wires hooked up in the 240 so these 4 should make it run.
The start signal (RB-43) probably hooks up to Hardbody (HB-34). There are so many possibilities from the HB FSM for those IGN wires and Power wires, I am going crosseyed!! I can't afford to fry an ECU (or worse)....Can anyone help??
--TJ
My resources are the RB motors FSM, pages EN 289-290 & EN 507-511, AND the 1994 Pathfinder FSM, pages EF&EC 149-151 & EF&EC 276-279. All of those pages give all the details for these ECU's...but it gets confusing. Is Carl H still around to help with solving this riddle? lol
Modified by s13_240_rb20 at 12:50 AM 4/8/2009
