qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Mon May 07, 2007 8:31 pm
Which fuses? The mini blade fuses should just pull straight out. The larger 30-100 amp fuses under the hood in the main fuse/relay box should come straight out as well but are a little harder to pull. Do you have a photo of what you are trying to pull out? Any more details would be helpful because fuses just aren't usually that difficult to pull out.
