odpl_DanW »
https://forums.nicoclub.com/odpl-danw-u110491.html
Wed Dec 31, 1969 5:00 pm
Ive rebilt many datsun carbs ; let me guide you. On disasembly keep yur base directly in front with screws left in holes. main body above it (front ¢er), carb top abve that,screws in holes. All pices top side up, sprins and thigs on left or rightdependingwhich side they g inpay attention to ck balls and springs. Line up all small parts how they go.
Spray w/cleaner in out and thru passeges, beckwash, and chase down ck balls you forgt to remove.
short cut: remove ld only while on car,turn back on linkages carful tto hold all screws, spray gently, inclding idle adj screw hole. do not openflaps untill you retrieve ck balls &their hold down srrings
