DriftRebel »
https://forums.nicoclub.com/driftrebel-u167689.html
Fri Feb 04, 2011 7:29 pm
Thanks ^^ but i already checked the coils and they are not getting power.....
I manually turned my CAS with my key on the "ON" position and my fuel injectors were NOT getting any fuel and it is STILL NOT getting any spark... Now im pretty sure that when you Manually turn the CAS, the ECU thinks that the engine is running so it sends fuel to the injectors and spark to the coils so now my guess is that i have a bad CAS or my ECU is all messed up.. Or worse than that, my wiring is all jacked up! I hate wiring!!
But anyways, i need some help trying to test my CAS a different way than manually turning it cause i need to see if i should get a new one from somewhere. I dont know anyone else that has a RB20DET and so i cant just plug my CAS into another car to see if it works so i need an alternative
Thanks
ANY HELP would be aswesome!!
