Need help on pulling an engine.
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
kingkilburn
Car: '93 240SX
I'm going to be pulling a motor tomorrow. While I am mechanically inclined I tend to get a head of myself with these types of things. What would you guys suggest I take out with the motor knowing its going in an S13? I plan to get as much as possible(half off day at pick-n-pull) all at once.
craigztoyz
Car: lots of unique hot rods, and customs, with modern engines, and a good truck to pull the trailer.
Search, this was discussed a month or tow ago.
Eng, its wiring harness, and a foot of wire after the connectors if you can, all the accessories, maf, intake pipe to maf, hoses, belts, everything you can grab that is attatched, mounts, with the rubber isolators if good(easy to make solid) computer, fuel pump is a good thing too, VIN #, and any history you can find in car, to chase down its maintance records. PULL A VALVE COVER OFF< If there is sludge in engine, don't get it.
kingkilburn
Car: '93 240SX
For 60 bucks I'll take what ever I get. At the very least it will be a dummy block for mock up.
craigztoyz
60 wow, that is cheap, yeah, take all you can get, and at least it is parts for the build and if needed, mockup parts. Good find, what year?
kingkilburn
Car: '93 240SX
Ya its 50% off day at a local yard and they have a flat rate type of pricing. All engines are 120(every day price) so I was ready to get it at that price.
The year I don't know but it is a first gen Q45.
I know a guy who owns a machine shop so it wont be to bad to rebuild. He decked my KA head as well as redoing the valve shims for free.
kingkilburn
Car: '93 240SX
Well I got my engine home. It took me about 6 hours if you remove the break time. I'll post pics in a couple of hours.
editI know this sounds stupid but how do you get the torque converter off? I have never dealt with an auto trans before so I am way in the dark.
Modified by kingkilburn at 6:47 PM 7/18/2008
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
$120 is the normal price I paid $1500 for my VH and that's a bargain over here
craigztoyz
The converter is a P.I.T.A. the first time. You hav to pull starter, and go through that hole with a socket and extension, Vise Grips on ringgear, and it should work out, Be sure to pull the front covers and get a good look at its tensioners, and sludge check. What year? Wait till you try the cam bearing caps. worst ones I have ever dealt with. Must be cleaned first, and then hammer a (high quality) bit in there, forgot the size, but you will probably use a few bits to get them loosened.
kingkilburn
Car: '93 240SX
I'm not sure on the year. I forgot to check the vin. Can you tell from the ecu?
npez
Car: 1993 Nissan 300ZX Turbo (soon 2B twin-turbo 450ZX) 2002 BMW M3 2008 Honda Odyssey Touring (Mama)
kingkilburn wrote:I'm not sure on the year. I forgot to check the vin. Can you tell from the ecu?
The prod date is stamped on the engine. I believe you can see it (my motor is in the engine bay at the moment) when you look at the shiny part of the block at 12 o clock above the flexplate - you'll also see the engine code (VH45DE) stamped there as well.
Nick.
tmorgan4
Car: 2000 Nissan Pathfinder
Chrispy300 wrote:$120 is the normal price I paid $1500 for my VH and that's a bargain over here
WOW!!! You can buy a nice Q45 for less than $1000 here! I never really appreciated the cheap cost of the engine until you hear what others are paying. VHs here in the US seem to be sold at about the price of the material they're made of.
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
You can get to the torque converter bolts through the access space right under the oil pan. No need to remove the starter.
craigztoyz
But to use the plate in a adapter sheid way, then you have to, the sheild goes around the starter hole, so it can't be removed. Or at least that is what I remember of doing it.
SuperHatch
Car: 96 TLC
nissandoms47 wrote:You can get to the torque converter bolts through the access space right under the oil pan. No need to remove the starter.
Ditto, that's how I did it on the 4 Q45's I've pulled motors out of, and that's how it's done in the FSM.
thejapino
Car: '93 J30t
$60, good find. Thats a GREAT way to start a vh swap project!
There are always a couple of G50's in the yard near my house but you have to wonder about the condition of the motors when the bodies are clean and wreck-free (how did it end up in the junkyard???).
Hopefully the motor isn't trash but for $60 and pnp's 90 day exchange policy, you can't really complain.
kingkilburn
Car: '93 240SX
It is a serious ***** getting those bolts out with the ring gear moving the whole time. If I had known I would have taken them off while it was still in the car.
I've had this stupid rental cherry picker for going on three days know because I haven't had time to get the converter off so I can get the motor on the stand. I could have just bought the damn thing.
Edit I have also noticed that the oil filter tree is broken. Not having seen one before I didn't realize until I really got looking.
At least it was only $60
npez
npez wrote:The prod date is stamped on the engine. I believe you can see it (my motor is in the engine bay at the moment) when you look at the shiny part of the block at 12 o clock above the flexplate - you'll also see the engine code (VH45DE) stamped there as well.
Nick.
Correction the prod date is stamped on the rear main seal cover - you'll need to take your flexplate out to see it. I just popped my flywheel off and saw mine again.
Thanks,Nick.
craigztoyz
kingkilburn wrote:It is a serious ***** getting those bolts out with the ring gear moving the whole time. If I had known I would have taken them off while it was still in the car.
Thats why I do it through the starter hole, the tension of the rachet's extension on the housing allows it to not rotate.
Nick, pulled flywheel again?
npez
craigztoyz wrote:Nick, pulled flywheel again?
Yep - The motor won't clear the engine stand with the flywheel on. I was taking the pan off to send that and the turbo housings to High Performance Coatings for the hipercoat extreme treatment. When the manis are done, they're going as well.....
Thanks,Nick.
npez
Nick.
Thanks,Nick.
Return to “VH45DE / VK45DE / VK56DE Forum”
