need help on my 1984 300zx turbo
A home for 1983–1989 300ZX owners!
jemerich
Car: 1984 300zx turbo
ok here we go i just got my 1984 300zx turbo have some problems it starts up fine but after running for like 20 to 30 min it just dies out and does the sam if your driveing the car. when i bought the car it would not run longer than 2 min but i just kept giveing it gas and go throw it and it ran fine for like 2 months and no it dies out after 20 min i ran the codes i go 23,31,41 someone said it might be the tps or Idle Stop Solenoid idk can u guys help me out
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
sorry I don't knwot he codes off hand but you definitely need to identify them and fix them before moving forward, be sure to ppull and clean al your electrical connectors as corrosion can be an issue, that being said sounds like the car dies after warming up, I have found a few causes fro this, the first is the CHTS (Cylinder Head Temp Switch) it's located on the bose of the drivers side engine head behind the timing cover, it can be done without pull the plate but is a huge PITA, the other problems all involve part failures with heat, fuel pump, coil, and ignitor are a few
Return to “300ZX (Z31) Forum”
