A haynes manual would help, but here goes. The oil pump shaft should have a notch on the top. the dizzy shaft that slides into the o/p has a small hole in it that lines up with the notch. slide it in and just start the bolts in the o/p. Now look into the dizzy hole with a good light, the tab on the end of the shaft should be at the 11:25 o'clock position with the bigger surface to the right (the tab is slightly off center). You may have to r/r the o/p 2-3 times to get it right but that's where it has to be. Once you achieve that, put dizzy in and hook it all back up, adjust dizzy timing with a light (vac on dizzy pulled and plugged) . Set and go driving.
Maybe this will point you in the right direction
