Need Help!! O2 sensor Bank 2 Sensor 2
gdeorta
Car: 2002 NISSAN MAXIMA SE V6 3.5L
alright well i recently had a SEL turn on and i took it to my mechanic, he put his solus diagnostics reader and is saying that that sensor is the problem, it also says that it is not recommended to use an aftermarket O2 Sensor, also says that even with replacing using an oem sensor it could still fire the same code and that it would need to be taken in to the dealer to be reprogrammed.... Any truth to this? :confused: anyone have the same problem? what should i do?
Thanks,
Gabe
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Did he give you the trouble code? If not, go to Autozone and the likes for a free scan and get a printout of the fault codes. Yes, in some cases, a re-programming can eliminate a fault code/
