Need help for oil catch can setup..
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
So i'm gunna run a oil catch can on my boompty...
To the people who have done it on a CA only please help.. Did you connect the left and right rocker cover outlets into 1 ? By the way i have searched all over the engine bay, this is the way i have to do i..
Anyone ?
float_6969
There is a BIG writeup about it somehwere in the archives. I don't have time to look, but I know it's in there....
rico05
Car: 1992 RMS13 w/ CA18DET
I used the line that goes from the exhaust valve cover and ran a hose to the catch can, then from the catch can to the turbo inlet. Later, I replaced the turbo inlet with an air filter on the can.
float_6969
rico05 wrote:I used the line that goes from the exhaust valve cover and ran a hose to the catch can, then from the catch can to the turbo inlet. Later, I replaced the turbo inlet with an air filter on the can.
Unfortunatly, this only covers half of the system. This will work when you are boosting only. Any other time, the manifold has more vaccuum and the gases will be drawn directly into the manifold. The easist way would be to run 2 catch cans on each valve cover. The other option is kind of complicated. I don't have access to the bitmap diagram that I made of it right now, but I'll try and post it up later.
float_6969
My searching > Your searching
zerothread?id=81100
rexhunta
MY10 Forester X LE
float_6969 wrote:My searching > Your searching
zerothread?id=81100
Thats why you found it. We call it rocker covers, or cam covers, not crank case covers Thanks mate
float_6969
Acutally I think I searched "PCV catch can", or something like that.
rexhunta
MY10 Forester X LE
float_6969 wrote:Acutally I think I searched "PCV catch can", or something like that.
Wouldnt've even thought of that. i searched Oil catch can and uhh, you can guess all the results i got for that. I tried skimming through most, but CAs where the hardest to find.
Thanks though.Pete
float_6969
did you know that you can narrow it down to just the CA section when you are searching?
rexhunta
MY10 Forester X LE
float_6969 wrote:did you know that you can narrow it down to just the CA section when you are searching?
It was 7 am.. hehe. But i'll try to keep searching for things. thanks though.
float_6969
LOL, no prob. Just trying to help.
rexhunta
MY10 Forester X LE
float_6969 wrote:LOL, no prob. Just trying to help.
I know. It's a first from a Mod Too bad that Tenkawa Akito bloke doesn't do **** around here
