Roger_cha »
https://forums.nicoclub.com/roger-cha-u47520.html
Tue Aug 02, 2011 7:08 pm
hey i got a 02 spec v that i just change the head gasket on it, after i did that i start it up it wont idle i have to keep my foot on the peddle so it wont die on me, i even did the idle relearn that help a bit but it will only idle 5 seconds longer only then it die. i check everything from doing my timing to every hose and wiring. when i put my foot on the gas peddle but it is very sensitive cause when you try to press it firmly just so it can idle to 1500 rpm it just jump to 2000 to 2500. ive let it idle long enough to get an engine check light but it throws a p0300 code which is random misfires only which i have that code before the head gasket change can anyone please give me some advice thanks.
