Remember, this pulley is dampener as well. It is balanced and has rubber impregnated in it. One of our members have one on his pulsar, so i guess it can be done. Don't really know if it's worth sacrificing looks for dependability, but again one of our members have one on his haltec controlled pulsar and you may want to look him up.zmannz wrote:While this topic is here anyway, I have a question. Can the factory pulley be upgraded to a lighter item or does it have a counterweight in it? I have to attach a Ford EDIS 4 missing tooth gear to mine to get timing for a Megasquirt 2, and I would just love to have a nice looking lightweight pulley while I am at it.
Update: I only have one RWD piece left and I prefer to keep it since they play an important part in my standalone set-ups.boost_boy wrote:You are looking for a needle in a haystack! I'll check my garage to see if I have an extra one.
Dee
Have you guys ever thought of the CA18ET's dampeners. I don't think these dampeners were built for the short term. I have yet to have one fail on me. However, I just had one fail on my 4G63T powered 1995 Hyundai Elantra and that things is the worsein the world to change as you have completely lower the engine to get it out. I wouldn't worry about the nissan ones just yet.jt15833 wrote:what will the options be for us when the crank dampeners run out? move to a solid unit and balance the rotating assembly?
True, but that's kind of an expensive experiment if it fails. I still wonder, though, if an experienced machinist couldn't make one that worked.float_6969 wrote:You could try it and see what happens?
Your machinist is both right and wrong. You can actually balance the crank without the pulley, considering your pulley is in good shape. I had mine balanced and lightened with just the lightweight flywheel and there's no ill effect in the higher rpm range.zmannz wrote:I was told by a machinist yesterday that I could not balance the bottom end of my ca18det without having the pulley on it. I thought you could counterweight the motor internally on the crank or with the pistons some how to eliminate the need for balancers. Right, wrong?
This confused me a little. I want to use a lightweight aluminum pulley with one v belt spot, one gilmer tooth gear with a built-on "keeper" lip on the front and in front of that a missing tooth gear for edis 4. I can have the gear made. So, is it possible to get the rest of the stock bottom end balanced enough to still rev to say, 8000 rpm's reliably and repeatably?boost_boy wrote:Your machinist is both right and wrong. You can actually balance the crank without the pulley, considering your pulley is in good shape. I had mine balanced and lightened with just the lightweight flywheel and there's no ill effect in the higher rpm range.
Dee
