I hear you re: don't want to be taken. I purchased a replacement motor from LQK. It arrived damaged and it was in worse condition than expected. LKQ does not offer pictures of their motors so it's basically buy and pray for the best. If you're lucky enough to find a motor make sure it is identical to what your replacing. The motors are not the same they only share the same 5.6 badging.
Yah, the early VK's weren't VVEL and won't work for you. The list I posted is all VVEL-equipped MY's.reggiebrown40 wrote: ↑Wed Jul 27, 2022 10:02 amIf you're lucky enough to find a motor make sure it is identical to what your replacing. The motors are not the same they only share the same 5.6 badging.
Those motors, with the exception of the M56 and the Q70 5.6 that you listed, will not work. The others are completely different motors and are not compatible without extensive custom work.VStar650CL wrote: ↑Wed Jul 27, 2022 10:13 amYah, the early VK's weren't VVEL and won't work for you. The list I posted is all VVEL-equipped MY's.reggiebrown40 wrote: ↑Wed Jul 27, 2022 10:02 amIf you're lucky enough to find a motor make sure it is identical to what your replacing. The motors are not the same they only share the same 5.6 badging.
I'll defer to your better knowledge, but if he can't treat it like a short block and transfer parts, I'd say he's in big trouble. Good luck finding either of those two.reggiebrown40 wrote: ↑Wed Jul 27, 2022 10:35 amThose motors, with the exception of the M56 and the Q70 5.6 that you listed, will not work. The others are completely different motors and are not compatible without extensive custom work.
